Rules & Guidelines | Canon Lens Code
FS: Glidecam 2000 Pro For Sale
Kenhead
p.1 #1 · p.1 #1 · FS: Glidecam 2000 Pro For Sale
     Glidecam 2000 Pro
Item still Available
Price: $150.00
Shipping instructions: Shipping included within the U.S.
I am looking to sell my Glidecam 2000 Pro. The unit is in perfect working condition with only a few minor cosmetic issues. (Sticker is peeling/few scratches) Asking $150 which will cover shipping within the U.S. as well as Paypal fees.
From the Glidecam website:
The Glidecam 2000 Pro is a lightweight, hand-held, camcorder stabilizing system which works so well that it allows you to shoot incredibly smooth and graceful shots even while going to extremes like running up and down stairs or traveling over rugged terrain. And when it comes to normal shooting, like walking or moving the camera slowly around someone, the results are equally magical.
Shot after shot, move after move, the Glidecam 2000 Pro delivers beautifully smooth and professional results. So good in fact are the pictures it produces that is by far the best and most versatile camcorder stabilizer available on the market today.
The Glidecam 2000 Pro's offset handle grip is attached to a free floating, precision Gimbal, which allows your hand to move up and down, and side to side, thereby isolating your hands unwanted motions from the camera. The up and down movement alleviates the bouncing, pogo type action so often associated with our competitors system, because their handle cannot move up and down.
The camera platform moves back and forth, and side to side, to quickly allow you to adjust the cameras horizontal balance. By varying the amount of counterweight disks on the base platform you adjust the camera's vertical balance. When balanced properly the camera floats, ready for you to move into action.
The Glidecam 2000 Pro will support any camcorder or movie camera from 2 to 6 pounds in weight. It is quick and easy to set up and balance. Allows unrestricted Booming and unrestricted 360 degree Panning. Only 14.5" tall. Made of precision Aluminum. Can also be used as a Monopod, no-tools telescoping base, with positionable weight discs that allow you to achieve dynamic balance. You can easily attach a small LCD monitor to the base monitor mount hole if needed. Weighs 2.1 pounds without counterbalance disks.
SPECIFICATIONS
• X,Y Head Dimensions: 6" x 4.25" x .75"
• Base Platform Dimensions: 4" x 10"
• Central Support Post: 1" diameter
• 14.5" tall in shortest mode
• 19" tall in longest mode
• Weight: 2.10 pounds without counter weight discs.
• Each Counter Weight Disc averages 2.95 ounces
• Camera Plate has 1/4" mounting holes
• Made in USA.
•Instruction manual is available via the Glidecam website
Glidecam 2000 Pro
Glidecam 2000 Pro Mounting plate and arm
Glidecam 2000 Pro Base plate with weights
Mar 12, 2017 at 02:32 PM
